Carburetor (specs) Database: SuperJet and Blaster 1
95FX1
brrrrraaaaaappppppp
been trying to get my dialed in with nooo luck for 2 weeks now!!??
61 x MOD 46mm carb...no venturi
coff pipe
MSD enhancer / coil
fiber reeds
velocity stack
120 low
130 high
cannot find what the turns out should be...i set the low at best idle...should i go a lil bit in on that even though it wont idle best...?
at 1/4 throttle it blubbers??? so low jet is to big right?
its fine if i go full throttle and pulls hard...130 is the main jet
if im just moving and chilling around its horrible??
gonna try 115 on low tomorrow.....2 weeks of trial and error is killin the FUN of my ski totally!!!
any thoughts?
motoman96
Banned
Lodi Cali
Brand = riva
Model = powerbomb
Size = 48mm
Quantity = 1
Main Jet = 135
Pilot Jet = 130
Needle/Seat= 2.5
Pop off 95g spring
Pilot screw = 1.5 about
Main Screw = 1.5 about
return line restrictor= 60 pilot restrictor
61x motor, dual stage reeds, girdled head, FX1 B-pipe, TDR waterbox, enhancer
Passes 10sec WOT run if you can hang on to the squirrly thing for that long at WOT.lol
Hallo, iv a new rebuild 6mm Billet DASA engine. Carbs a dual 48FS Novis(Not coml.bored to 48) or dual 46s.
Have somebody of you startingpoints for jetting ????
Thanks,Andy
Waternut
Customizing addict
Macon, GA
This is the greatest thread ever! I took an engine that I've never run and slapped some carbs on. My only technical assistance was based on the jetting from this thread and was able to tune my ski in about 5 minutes. I was fearing days of frustration and jet swapping.
Brand = Mikuni
Model = GRS
Size = 44
Quantity = 2
Main Jet = 115
Pilot Jet (front) = 120
Pilot jet (rear) = 115
Needle/Seat = 1.5
Spring = 95
Pilot screw (front) = 1 3/4
Pilot screw (rear) = 1 1/4
Main Screw = 1 1/4
Gas Octane = 93
Altitude = 300
Main type of riding = flatwater freestyle
Would it pass the 10 second WOT test = will never know on my ski but 3 seconds and the plugs look good
Powerband = hits good everywhere but comes on really strong mid to top
Motor type/setup = Speedwerx 771 big bore 62t/61x - Tim Carlson's old race motor - 26cc domes with R&D dominator pistons
australia
Brand = mikuni
Model = aftermarket
Size = 46s
Quantity = 2
Main Jet = 105
Pilot Jet = 130
Needle/Seat = 2.3
Spring = 115 (21PSI)
Pilot screw =1/ 3/4
Main Screw = 1
Gas Octane = 98 (aus)
Altitude = sealevel
Main type of riding = freeride surf
Powerband = everywhere
Motor type/setup = infusion t ported 701 epic b pipe , usual bolt ons
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
Brand = mikuni
Model = buckshot
Size = 46
Quantity = single
Main Jet = 140
Pilot Jet = 115
Needle/Seat = 2.5
Spring = 95gold ish
Pilot screw = 1
Main Screw = 1-1/4
Gas Octane = 93
Altitude =
Main type of riding = free ride
Would it pass the 10 second WOT test = all the time
Powerband = low is good it pulls hard mid to top
Motor type/setup = 750sp, ngkb7ev, 190psi 26cc cut stock head, home port work+boost ports, wiseco pistons stuffed and polished, lighten flywheel msd coil+enhancer, pjs intake, case porting, vforce3 reed and spacers, w/c manifold ffp 650chamber, badbones w/b drilled drive shaft, c75 13/17 r&d afterburner, worx grate, op finned plate.
I can't find anybody running DUAL POWERBOMBS.
Any tip is welcome snce I was familiar with Full Spectrums instead of this.
Thanks
Gera
Does anyone have a good baseline set up for me?
62t bottom end 61x topend, riva girdled head 35cc domes, stock porting, riva drypipe, and twin oem 38s with k&n flame arresters, and dual stage carbon fiber reeds, unsure on brand. I currently have 130 mains and 70 pilots, and 1.5 needle and seats.
but i got a couple hours a tuning in today with.
heres my semtums=
1. the throttle response seems to be pretty darn good up tell about 3 or 4k(wish i had a tiny tach it would prob help) its just real gragally and motor runs rough but has always idled rough ext.
2. low and high screw out three turn seem to be getting closer
3. and a wot throttle test i cant get there it wont let me the rpms stay consistant but it sounds like its a hell of a missfire thats some(GRUGGLY)
4. once i opened up to the three turn if i worked in to the gas progressivly after the power band it will continue to go and eventually hit another power band(only felt it once but then i lost control and wipped it)
5. if u cruise around at slow enough to renmain stable on my knees for how ever long i can nail the gas and its does exactly like number 1.
6. i know my pop off is set at 22 cause i raised it from 11 when i rebuilt the carbs and it would eventually load up before the carbs and hit a lean spot on wot throttle test.
my septup is as follows
superjet
mukuni 44 mm buckshot carbs
pilot 110 goes to finger discharge
main 130
needle and seat 2.3 and 22 psi pop off
ski= 62t case/61x cly with free ride port.
bored .75 over pushing 190-195
riva racing intake mani with no cross tube, boyseen dual stage reeds(not stock cages?)
msd enhancer and msd coil, factory b pipe with raider chamber, strightpiped .
blowsion air forced air filters with some prefilters
each carb has its own fuel pick up and filter
and from my current jet sizes i have switched from 93 to 100ll aviation fuel. it was running on 93 before i got my parts ski but i up compression and added port work
HELP please. i will have main and pilot size tomarrow once i open them up
thanks helpd alot!!! same setup but with protec pipe....runs loke a champ!!! bbrrappp
Brand = Mikuni
Model = (From XL760)
Size = 44mm
Quantity = 2
Pilot Jet = 110
Main Jet = 130
Needle/Seat = 2.0
Spring = 95g
Pilot screw = 1-1/2
Main Screw = 1-1/4
Gas Octane = 98
Altitude = Sea level
Main type of riding = Freeride
Would it pass the 10 second WOT test = YES !!
Powerband = Bottom to midrange
Motor type/setup = 760 (62T 84.25mm cyl/62T case), soft case porting, 165PSI ADA Girdled head, VFORCE 2 reeds, Factory "limited" B Pipe, 650 cutted F/A with 2 screens, 4° static advance on stock CDI, R&D ported intake manifold, dual signal lines/ dual fuel lines.
thanks setup works good as a starting point...i have same setup but with pro-tec pipe.....brrraaappp
I got twin 38s on my sj ported motor, b pipe, Riva head with 175 psi. I recently bought this ski and it has 80 and 145 jets and hasn't run right since purchased. Are these jets too high?? Someone told me to go back to 137 and 77 . Any advice?? I will be checkin pop off soon
My advice: Go through every post in this thread and find a setup similar to yours.
IMO your jets are too fat.
munki63
Epoxy is my duct tape
Canada
I have a very similar set-up but with dual 44 and I was running 100 Main and 100 pilot
munki63
Canada
XS771 Ported cases & cylinders
XSR 46mm SBN carb set specs (XScream Modifications):
112.5 High with 5/8 turn out
117.5 Low with 1 7/8 turn out
2.3 N/S with 65 gram spring
# 70 Return line jet
Edit: Mostly So I dont forget
Hi everyone,
I've searched like a crazy person, but so far I did not find the answer I'm looking for. So please excuse me if Im asking on the wrong place (I'm a stupid Swede, I dont know better). =)
I ride a 61x/62t with Watcon Sleeves #1820 84mm, with mild case porting, ADA head w/ 33cc domes, Factory Limited pipe, MSD Enhancer, K&N flame arrestors and stock Mikuni SBN 38's.
I ride at sea level and on 98octane fuel. Mostly freeride. However, i've been having some trouble to get the jetting right even after ALOT of testing. I know there are very much knowleauge about these engines out there, and my question is; Do you guys think I need bigger carbs, or do I just need to get the jetting in the 38's right?
I think those carbs should work fine.
Jetting should be somewhere around 1.5 N&S, 95g spring, 75 pilots, 135 mains.
Thank you Matt, very helpful!
It's been a few months since I took it for a ride, and last time I had 1.5N&S and 95g spring and 72.5 pilots (cant remember the mains). Back then it was lean on low speed so I changed to a popoff on 35psi and to 75 pilots. And when took it for a test ride today it was rich as hell... Did'nt think about the temperature difference those months made.. From 32degrees to 80degrees makes a big difference in jetting...
Thank you for reminding me about that, even without saying it. =)
58vwragtop
Braap Certified
Blue Springs, MO
Just wondering if anyone had any specs for the dual 44 BlackJacks? I just had Art do mine and they seem way to rich.
