Crabs X2 winter buildup
Legdragger
Bringing it back
New Hampshire
A spacer between the coupler on the crank and the coupler on the drive shaft would make up the 6mm (1/4) inch you need. If you impeller is set back you would need to account for more spacing though.
Crab
thanks darin...noswad!
Seattle
:Banane01:Rotation rocks. And I got the green light to go to DAYTONA in 08!!!!!!!!!:Banane01: Someone hook me up with some ride time, please.
Crab
Seattle
You too with the blaster L. chamber...lol
Nice reeds, and what waterbox is that?
Not my picture, just bought it from Alex on here. I want to try it if it lays in there like Bluebread says it will and compare to my current setup. If its the same or better, that free's up an SJ chamber.
Crab
Seattle
While down for repairs and a new starter, decided to mock up and install the beasty one. Some minor clearancing at the manifold with a peen hammer, and ground off the lord mount completely, but looks like a tite fit. Hope I can get the fuel tank back in. I also mocked up the exhaust spacers shown a few posts above, they put the headpipe just toutching the hull so I decided they may go in the new X2 hull where there is more room.
dbrutherford
Parts Whore
Fairmont, WV
Let me know what all is necessary to fit that chamber in there once you get the ski all back together. Looks like you had to grind on the exhaust manifold some.
Nefarious
Can't... Stop... Modding
San Diego
It's a pretty easy fit; cut the lord mount off and clearence the chamber with a hammer where it contacts the remnants of the lord mount.
Crab, I had to install the tank before the waterbox and tank before the chamber.
dbrutherford
Parts Whore
Fairmont, WV
As in lord mount you mean the one up by the stinger. Or do you mean the mount on the exhaust manifold?
I have a FPP exhaust manifold I am going to use and don't want to go cutting it up :(
Crab
Seattle
Not sure thats going to work, my wb is a beeitch.
