Soon as I can find my f-ing camera....:banghead:Pic's crabman?
That hump, shields the water from my relocated air tubes, it is functional for me.
It works fine, I ran it like that last summer. Its like having a snorkle up high.that's a great idea let me know how that works out for you.
Ok, got the pipe to lay in there flat to the headpipe after cutting at the lord mount, but now there is only about 1/8 inch between the flange at the coupler at the exhaust manifold. Its really going to be snug by the time I get the coupler in there, I wish I knew how thick the casting is, as I need to shave a little off it. Perhaps I can trim a tiny bit at the flange also, as it just keeps the clamps from going anywhere. The pipe seems to clear the cases ok, but I don't have the front cover on yet. This is going to be a very tite assembly, but hopefully worth the trouble.Slicker, it hits at the bottom corner of the lord mount, I am going to cut about 1/2 of it off but save the top for use with my Coffmans if needed later. I think it will clear the cases just barely, sure is purdy!
Look at post #67.You got any pics of that set up? I need a project. . .
Wow that looks like it would work pretty good is that just ABS pipe? I may have to try that this spring. Did you put some foam back on the inside of the hood? If not do you think that you have enough flotation on the ski without it?
I have seen some who hang some plastic or rubber sheet down like a shower curtain to keep water away from the carb.Thanks that's good to know I may tear into that soon. I hate where the air comes in the hood now, it just dumps right on top of my carb, and since a sub is really the only trick I can do it's no good.
Found it!Soon as I can find my f-ing camera....:banghead:
I need to heat mold the tank over just a little, no big deal.:Banane01:Crab, You should be able to cut that lord mount down more to give it alittle more clearance. Have you mocked it up in the ski yet? I an currious how it will fit with the tank.
Lookin' good Crabman. Keep the pics commin' and keep up the good work Get that thing done for the freeride. :arms:
