D-Roc
I forgot!
- Dirty River Rider
thanks, i wonder how it will work. haha.
This morning i sanded the sponson an then did some composite work on it. wrapping the material all the way around is a challenge so i "vacuum" bagged it. I should probably go back out and finish up the second side of the tray. I also should go take another look at the nose of the ski as i have been asked to do something about it.
i was getting the feeling that the break in oil thread was no longer about oil. Also I have not used a dremel on this project yet. i used to have a dewalt cut out tool with a drywall bit that worked well, but it is MIA. It would appear as though my sponson work turned out not too bad. i have some sanding to do if i want it to look a little bit pretty. Tommorrow i should be able to see just how nice i can make it look, not sure how worth it will be. i gotta bond these things on and think they need to be on there really good. You have a set of X3's , that are not installed, ? they install very far back in the tray. the best way to do them is to just jump into it like you know what your doing. lol.
FWI i only work on my own crap.[/QUOTE]
I tell people the same thing. I figure if I keep telling myself that eventually it will actually work out that way. (it aint workin worth a dam yet tho)!
