- detroit MI
well it depends who you ask and what u do. a 144 pump has supported a 1000cc engine. is it ideal i would say no.... i would build to fit as big as you can. that way you are never limitted
What about a stock pump with a chewed up stock impeller? That's what I'm running right now. I did double check the seals on everything when I was doing the 760 swap but I guess it's worth triple checking. Where I'm at is I have a 155 pump and trim with an impeller that I know worked ok with this engine and I'd rather not spend the cash on a new impeller for the 144 pump that I'm ditching after this season anyway.There should be no way you would overpower a stock pump with a 760 and a pipe unless you have some sort of issue with the seal, stator or prop. I would figure out where the problem is first before swapping in a lager pump.
so are the mounting points of a 155 pump wider than a 144? how much wider?
what about fore/aft direction?...is that the same distance as a 144?
what is the limiting factor of putting a 155 in a SJ? ...other than the intake scoop area size being smaller...does the 155 have enough room to sit where the 144 did width wise?
A few have, @D-Roc comes to mind...So have any of you actually put a 155 into a 144?
It hard or impossible to get a rideplate to protect the pump or plane out properly as it hits. Hard to get pump bolts in and whatnot. Ive put a 144 setback skat running a xs1000 in a squarnose pump tunnel to discover the tunnnel robs even a 144 its true potential. I just wanted to clarify why pumps and tunnels need a clean handshakeSo have any of you actually put a 155 into a 144?
They call it blue printing a pump because you remove the casting irregularities and imperfections from when it was first created at the factory.I mean I'm not trying to be an ass or anything. I've been in a tool room for 9 years now. When I went to school they beat that terminology into are heads. I just don't get how everyone started using that term for that kind of job. But any ways back to the original question about the pump. I am curious my self on this. I've been contemplating building my own hull but curious cause I don't want to add a pump I'm going to max out.
