ExactlyBig horsepower numbers are easy to generate with a little more RPM. I know it gets people exited but those 7700 RPM dry pipe setups need a lot of help from race gas to get low end response and keep them from burning up. The pump gas, wet pipe crowd needs as much torque as possible while being able to run up to 7300 rpm.
Damn whats your problemIt's not going to have any more hp than a properly ported OEM cylinder with the same bore and CC. It's just another new, made in China, copy to attract the suckers that don't know better. Affordable power, it's coming.
How do you keep a sucker in suspense? I'll tell you all later
Explain your reasoning behind this statement.Personally I hate power valves on a ski engine
Probably ate some bad road killDamn whats your problem
My views, More to go wrong!!!!!!!!!! Got to clean them, Orings go bad sometimes, Bellows blow off, etc etc etc. My DASA 6mm Non PV (Billet) runs great. It is a good all around motor, ride flat water and surf. Not gonna be doing flat water backflips on it. But the power is like an electric train.Explain your reasoning behind this statement.
I'm looking forward to see how this project turns out. An 84mm cylinder that won't crack and has strong linear power with a good peak would be a great option for a rec and buoy ski.
Good 61X Cylinders seem to be getting harder to come by these days.It's not going to have any more hp than a properly ported OEM cylinder with the same bore and CC. It's just another new, made in China, copy to attract the suckers that don't know better. Affordable power, it's coming.
No it can't and that's the reason tpe made those bubble out transfers on the outside 4 corners, cause that's the only place you can change the transfer volume and design. The inside transfers are limited to crank, rod, piston spacing. And it's insignificant. Ocean pro vortex flame arrestor boast a 2 hp increase. I better get my neck brace outAn aftermarket cylinder can overcome some of the stock cylinders shortcomings in transfer volume and design and exhaust. It's not nothing.
I remember that old ad from TPE? Back in the day lol that specific line “affordable power, it’s coming”It's not going to have any more hp than a properly ported OEM cylinder with the same bore and CC. It's just another new, made in China, copy to attract the suckers that don't know better. Affordable power, it's coming.
That was never my tag. That was some "so called friends" wanting to get in on the action without putting out and work and labeling it that. It was misconstrued as to what that even meant. A 964 used the same pitch as a dasa 10mm 1000. At that comparison it was affordable, but that was never my statement.I remember that old ad from TPE? Back in the day lol that specific line “affordable power, it’s coming”
That's why I referenced it. Just another lie that kept everybody dreaming about something that turned into crap. At least it was true about having power at 965 or 1105, unlike this 701 turd. Was going to be fairly affordable until the powers that be, refused to sell just top end kits, because they didn't think the buyers could finish the build properly.I remember that old ad from TPE? Back in the day lol that specific line “affordable power, it’s coming”
That's jetskibuzzard , stupid. Just more hogwash coming out your both endsProbably ate some bad road kill
Somebodys feathers got ruffled, just know I can do this all day longThat's jetskibuzzard , stupid. Just more hogwash coming out your both ends
