ive finally gotten all of the parts gathered to swap to the zeel setup. picked up a clean used 760 ebox, flywheel and cover with everything but the solenoid. i bought a 01T cdi from a friend. got the flywheel machined and 3rd lump removed. this cdi did not have the factory plug but had oem bullet connectors so i cut the oem plug off and just used bullet connectors. dialed in a curve i liked, wired everything up and no spark. i verified 12vdc going into the cdi unit. i did make an additional splitter so i could connect to the rectifier, cdi and start switch so everything is hooked up. upon reading through this thread i did read that its possible if the rectifier is bad, it can cause a no spark condition. disconnected it, still no spark. i did take the ebox back out and apart to double check wiring. everything appears to be hooked up properly. no loose grounds. also tried to disconnect stop circuit as well. still no spark. to verify the cdi and coil are good, i connected the cdi to the programmer and performed spark test. had good spark while doing the test. so ive started checking the pulser coil. testing pulser coil resistance between w/b and w/r netted 485 ohms- spec is 445-544 ohms so its within spec. ive also removed the flywheel cover to check all components again. any ideas??
