DIY Total loss or MSD TL upgrade box 270USD?
Built it using software. Designed to run wet and peak hp at 7400rpm + depending on temp. Started out running it a bit hot each time we open the water screw valve up more it just pulls harder. I haven’t got a tac on it yet but I’m going to try and get one on it this week end. I’m definitely not on the limiter yet so I say it needs to be pitched down. Also I’ve not got the carbs completely sorted yet so I know it has more to offer.
TehXshizzit
#Killer City Rippers
H816
Never updated my results from my set up. Got the ignition in my 760 and put it all in my SN superjet. Ski has a lot of power, not sure how big of a difference the zealtronic made cause I never tried the 760 stock, but I will say it starts on a dime everytime now and runs awesome. Here is a link to a ride video
TehXshizzit
H816
not yet, I put music on top of all my videos cause its better than hearing the wind. ill make a video this weekend and post it though. here is the inside though.
TehXshizzit
H816
also, do you guys have any advice on what prop pitch I should run to help my low end, while keeping my mid-top end? I chase boats, but looking to race this season. TIA
davidescu_radu
sea riders
just installed one but with the rectifier plugged in i get no spark - when rectifier disconnected - all ok - i get blue spark - red from rectifier is connected on same red main connectors as cdi - that is main red from batt
Will a flywheel from an 1100 work on the 701 (760 cover and stator with Zeeltronic ignition)? IE, the crank taper is the same? I realize that it will only have one bump for the ignition pickup, but it looks like we could account for that in the Zeeltronic software. Plus if this flywheel is used you wouldn't have to grind the little bump off (760 flywheel) and possibly change the balance of the flywheel. I guess it could depend on where the bump is in relation to pickup and TDC (if the static angle is to great)?
waxhead
wannabe backflipper
gold coast
The answer is a clear NO. it needs two lumps 180 degrees apart.
You can use a zeeltronic with the 1100 ignition no problem. Its a different model zeel but it works well
