waxhead
wannabe backflipper
- gold coast
yes
fill in that intake crossover
i thought you had it done already
I've been watching you guys' thread waiting for an outcome. . . I got duel 44 problems myself. . . I just bought this ski and it's killer out of the hole but has a terrible mid range stall.
This weekend i will change the arm spring and LS jets. . . Do you mind if i chime in wit the results? . .I know it's not the same problem but i like to see what other pepole do.
here's my set up,62T:
LS-100
HS-135
NS-2.0
Spring-95 gram (around 25lbs pop off)
domed head,160 lbs compression, Cool head
Factory dry with ewci
It jumps out of the water if you feather the throtle, but if your up on a plane just cruising and go to jam on the gas it dies. . .the kid who had it before me is not a tuner and did not build it.
Very well, i shall disconect the ecwi when i test ride it.
It's a Factory pipe 701 Superjet dry pipe. not the type 8.
I ordered the 102.5 and the 105's. . .Should i just go straight up to the 120's?
good luck with yours Mark.
worn needle and seat
