Frosty
New York Crew
- Western New York
waxhead said:TO FROSTY
redtops
they are an anular discharge carb right ??
It would depend on the porting alot this could be making it sluggish down low
are you running water injection ??
what bore size do you have because 37cc domes will make for a very low compression and this in itself could be the reason you are slugish down low
let me know what jets are in it when you find out
also a comp check as i suspect its very low
Yep, they are anular discharge carb. supposed to atomize fuel much better.
No water injection (nor was it on the previous ski).
std bore 81mm
I'll check compression tonight too. I did run these domes on my other superjet, it too was std bore, but was not ported at that time.
I am also running a riva intake mani and spacer plate with CF reeds (on OEM cages)
I'll get more details on the carbs and compression after work... and go from there. Truthfully, I did not give compression much of a thought here, just because they came off another SJ with good all around power. I'll for sure check that out.
Thanks man...
