wayne
wannaroll
- Mesquite, Texas
What makes NGK better than champion??? Is this the type of comparrison like "which oil is better"???
I have seen tests show that cheap walmart oil held up better in a motorcycle than expesive motorcycle specific oil!!
If you own motorcycle, you DO NOT have to buy "motorcycle specific" oil. I heard it right from a Spectro sales rep and have seen alot of testing that proves it also!! Its all marketing!!!
ngk plugs will not melt. other plugs have had the threads melt to the threads in the head and when you pull the plug the threads get ripped out and have to be helicoiled. when i worked at honda i saw a few cars that use ac delco or bosch platinum (sp) and the heads had to be pulled and the plugs threads had to be helicoiled. high reving engines should have ngk for cheap insurance. first time you over heat and have to replace your head you will understand.
