Wolf Child
Just Another Octard
- All over C. FL
should I get you a shovel to dig that hole of yours? or do you prefer your grapefruit spoon?
I meant lacks instead of needs, I didnt want to go back back through all the messages check! You know what I meant cause I was Quoting you! I would not use the $1 oil in my bikes but I will use the $2-$3 Castrol & Shell. I just know people/stunters that used the $1 stuff and never had a premature failure of any kind, thats all I am getting at! I am not recommending people to use $1 but I would recommend the Castrol and Shell! Those are the two I have recommended this whole time. The $1 oil talk was just interesting story/conversation not recommendation!
just a heads up on marketing guys, typically they don't know ******** about the actual product. i work with a lot of sales and marketing guys and they are not knowledgeable on the technical aspects.
I have no idea on bikes, but I work with seals for a living and test in various fluids. The various oils, coolants, ect are all not the same. The differences may not be enough for you to justify the increase in cost but they are formulated differently.
A beat up piece of ******** car might get me to work, but it isn't going to be as nice and smooth as a new one. All depends on my personal preference, but I wouldn't go telling people their isn't a difference just because my older beater hasn't broken down yet.
I wouldn't use the other brain because I did some research and found that flabber gaskets could rupture the shnufflegoffer.Dirk The Diggler, does your other brain work (that's the grayish substance located inside that round thing sitting just above your shoulders)?
Hey Wolf, let me know if you agree with this.........you guys seem to love to gang up on people! I didnt recommend the $1 oil, just saying I have know many people that have used it in their bikes without any issues!! Stunters would be the ultimate test because they beat the hell outa the bikes constant!! I use only castrol or shell and thats what I was recommending to people with Motorcycles!!
Hey Dirk, FMX guys are hard on their frames, wheelsets and suspension. But as far as their motors, I would say they are not hard on them at all, they only use MAX RPM right before hitting a trick, and if your talking street stunt, they hardley ever use MAX RPM at all since those kind of stunts are based off of balance not power used. A race bike(street or dirt) is the maximum amount of wear that any engine would ever have to be subjected too. MAX RPM 90 % of the time. So, your comments that "Stunters" would be the ultimate test holds no weight.
Guys, keep it clean........
he'd likely say " i'd rather keep my friction squares on the plates thank you... the bike moves a little better that way"Ask a Moto GP racer to run car oil in his bike and see what he says, not a stunta hittin stoppies.....
It was more accurate, huh?You know,
your original avatar was better.
