If i go back over the pages i see a few posts that still have me thinking. So, I am going to go thru some of the comments to try and make sence of it.
Talk to JD before you jump into the 148. He had one. Too much prop for his 865SS. 144 is perfect for his setup.
This one has limited information but It says to much prop, not too much pump. It also looks like the 144 size pump is what the 865SS comes perfectly tuned for. Most can agree that the mag 144 is better than the tbm bandaid version of the oem 144 pump. Both can work, one better than the other for obvious reasons. choose the cost.
bigger pump probably not required until you go over 1000cc
This is a more accurate statement: A bigger pump is required when running 1000cc for full advantage of motor. (big motor needs big pump, big pump does not need big motor)
Does a ported 701 require dual 48's? No. It does not require them.
Does it work way better than dual 38's? Yes it does.
Does the 865 require the bigger pump? no, not even to win A/M freestyle.
If runnning a motor straight out of the crate without tuning, will your need a 144 pump that the crate motor is setup for? Yes.
Does a 148 pump give you more bottom end and thus load a motor different? Yes.
If a motor gets loaded different will a jetting/popoff/carb adj. be required? Yes.
Can timing adj. from a TL ignition help change the attitude of a motor? Yes.
Will a 144 mag pump used with a crate motor tuned for 144 work better than with a mismatched 148 mag without tuning of motor and a prop selection.? Yes. 100 times more.
There comp boat in amature last year, was a bob ss865 and it had a 144 mag and it was doing back flips, I'm sure if a 148mm performed better it would be in there
What do the rules for amature freestyle say about running a bigger pump than what the yamaha 62t motor came with from the factory?
I have made a previous post about if you want the best than look at the podiums and see what they run. If it is a 865ss in a bob hull using a mag pump piloted by a skilled rider that won, that is indeed a winning combo. Lets look at the winning combo a bit. I see 4 main things, as do most people. The hull, the motor, the pump, and the rider. But what about The Tuner? (that guy). Sometimes the rider is also the tuner. Other times it is an uncle, dad, brother, maybe grandma. Either way, someone has to make it work better than the other riders that are playing within the rules. So, you are the rider, You buy a hull from the hull builder, motor from the motor builder and then who do you think you should go to for the pump combo? The internet says to ask your engine builder. hmmm. okay, he didn't ride my ski, but he can build winning combos. I guess I have to buy all those parts he recommends to have a tuned ski without tuning. Or, hold on a sec, lets think about the fact, that once you have a determined pump size/prop combo, it is a well known fact that the motor is going to have to be tuned to the load being put on it. That is what the Adj. of the carbs, pipe, and timing is for.
My own example. I started with a single 48 and then added a second later on to make it duals. I also had the tbm/prop put in. It was quite expected that i would have to rejet/adj the carbs for this major different change. once i had it tuned with different head pipe settings, timing, and jets/popoff. I was happy. I then only changed my motor to a bigger Dasa 771 PV. I used the same carbs/settings. I used the P/O's head pipe settings and timing curve to start. My pump load has not changed. The motor is stronger, and the ski ripped better. I now had a base map for tuning. I start my tuning and I got the ski to run better with a different timing curve and head pipe settings. I could have left it at the P/O. settings and it worked good but that was for his pump combo/ski setup and not mine.
You were just complaining that you won't spend 600 dollars more to get a mag but you would of tried every avenue if you were me.. You make no sense
Lol, yeah that happens from time to time. I spent 600 on the tbm/prop for the oem 144. I don't want to spend another 1100 to get a 144 mag that will work only a bit better than the blueprinted 144 oem pump setup i have. Especially if I can go straight to the 148 that i will not out build down the road. Yes it will cost more to do the 148 than the jetmaniac 144 mag. But I hope a smarter move then finally building up to 1000cc and need the bigger pump.
Now I am not posting this as a know it all. It can be more of a ski building 101 for newbies/dummies. If there is false statements that need to be changed then lets work with the data/ expertise of us all to layout the facts in a way that make sence. It has been said in this post that not all of us can buy complete designer ski combos. This is who this post is meant to help. Understanding how the parts overlap and work together can give the rider/builder ability to tune the ski. Then you know why it is a certain way and what needed to be done to achieve maximim performance with the parts used.
"If it worked right the first time, what would we have learned?".
This is a good point. I think most can relate to this when building skis.
You get hurt alot don't you?
Well if your asking....I can tell you a bit more about myself so you guys don't think I am high on myself. As a child I had friends with nice toys that they put away on shelves. In my room was boxes of toys taken apart and on my shelves where the toys that I made with those parts. I took stuff apart because I need to know how it works. The toys I made usually had wires, a motor, 9V battery, and my favorite....buttons. I can ride a jetski. really, lol. I can ride it better than some but not near as good as others. I usually try and ride in a way that doesn't hurt me or others. Sometimes i try and grow my balls and work on the tricky fancy air tricks. Luckily for me, I have a big c..k and impress my lady that way. Problem with a big c..k is, other people think your c..ky. haha, sorry mods i have a sence of humor too.
One more problem is I am part dutch. Wooden shoes, Wooden head, Wouldn't Listen. So I am not a pro rider, I ride flats alot on rivers and creeks, I love waves on the lakes but we get dry spells. I even survived daytona surf. Me and my ugly ski. I get up and go to work everyday to put food on the table for my family. Yes I have a son, and yes, one day he will start riding. And when he does, his ol man is going to know how to build a ski.
Thank you for reading. sorry if it is all useless. This was the longest most thought out post i have ever done and hope it finally makes a little sence. yes i am a bit crazy.
