Finally finished all the turf. I still have to get my bilge pump and mount a switch. I can’t figure out if I’m going to just use a rotary switch and mount it opposite of the primer or get something that mounts on the handle bars.
And I don’t know why but getting the breather tube through the hull from the handle pole is absolutely kicking my ass! I’ve tried twisting it to screw it in, I’ve tried greasing the hell out of it, folding the tube in half which just breaks it, and my last attempt was heating with a heat gun till almost melting and I actually got it in but only the part that was hot and then it was all jacked up and stayed folded in on itself. It’s a 2” tube going through the stock 1.5” superjet hole. Every time I try and grab it to pull through with a pair of pliers the hose just rips apart too. Am I missing something here?
