Foximus
CFL Cheapass.
- Oviedo, Fl
I still havnt seen any pictures that really show off turfed REV's to a satisfactory level...
My feet are too tight with 1/2" underpad on the bottom and turf only on the top.Love my REVs, going to install second pair this winter in my SN
You can pad them any way you want becuse they are big enough
I used layers of 8mm to shape them the way I wanted them
I always heard that splay foot was duck footed (toes turned out)
and pigeon toed was with the toes turned inwards??
anyone used the WCF ones? That was my primary concern... they look to small to use with 25mm pad and turfed.... I plan on sanding down the foam in the area a bit but not much....
XFT holds are the bomb don't count them out you need to ride a ski with them installed. I don't have them but have ridden an XFT ski and they were great it took a couple rides to get use to them.
Mark44
I'm ordering a set of ATP footholds soon. I like the 24/7's I ride now. REV's and XFT are way too comitted IMO. I may mod them a bit for slightly more enclosure, but nothing like the REV's.
when I first started getting into footholds and all that on my ski, people use to say stuff like... Won't your feet get stuck in there.?.. bla bla bla..
I think you will find that is a non factor. I do understand your concern though... fyi - REVs are very simple to get your feet out, since your feet are not duck footed... Revs will allow your feet to exit the hold from a wider range...
XFT holds are completely unusable IMO and I am refering to the REVs w/o the enclosures... you don't have to put those gay things on there... absolutely no reason for them...
