I couldn't agree more...this hull is mind boggling how it can be so tiny but so incredibly stable. It's way more stable at high speed than my full length Matrix was, but it's also extremely agile. I have cut 3" off my plate and I'm 6'4 230 lbs and it still rides awesome, I'll be cutting it even shorter right away here too.
Hink,it does surprise a lot of guys that have rode mine that it is stable at speed.But l think l am done cutting on the plate for now.Has a nice feel and l need to spend some more ride time with it.
Time for another surf trip! Just waiting on some decent conditions in Savannah.
l must have had a small pinhole in my coupler between headpipe and chamber.lt all started when doing an inspection in the engine bay when l saw a quarter inch hole in the bilge pump.The cover for the drive couplers vibrated a hole in the top.So pulled it out and noticed some nasty gray exhaust crap all over the motor mount,m/m plate and all over the area around and behind the exh chamber.Pulled the engine to clean the entire area and found that the motor mount was loose too.Cleaned everything up,re-shimmed and put everything back in.
l will say that after building a ski and a number rides that it is always good to basically pull the engine and visually inspect all of it, including the pump area.Leaks,anything loose,etc.l'm sure we have some perfectionists out there that don't need to do this but always wise.
