Not even CLOSE! Swapmeet has me beat by a crap ton of pages.Longest build thread ever? Lol
Well anyways, good job with your build and good luck with the first flip on video!Not even CLOSE! Swapmeet has me beat by a crap ton of pages.
Can't wait to get some footage.
Ok so I'm getting a mag pump. If my pump is working pretty good now, should my current 9/15 hooker be fine for my setup?
I'm thinking about getting a stubby cone to try too
Well I'm curious about the stubby since I'm running a stubby in my oem pump currently. But it'd probably be a good idea to try em both!Change one thing at a time grasshopper
Use the washers skat or impros sells.
Ditch the stock rubber washer, it doesn't work on the mag and could end up ruining the front seal. If you're cheap and need a washer, cut all the rubber off the stock one and run it.
There's a real simple way to get that answer.Ok so here's the question I need answered though; if my prop doesn't rub on the viens of a stock pump, does that mean it won't rub on a mag pump?
No there is not. You cannot prove it. We will prove you wrong.There's a real simple way to get that answer.
