Honestly I've cussed more putting my square back together after tearing it apart than assembling this hull. It hasn't been too crazy. You have to be a little creative at times, but nothing too out of the ordinary. It helps when you have access to lots of tools though, that's for sure. Honestly the whole pump area was the hardest part for me so far since I had to figure out how I was going to do my trim setup, etc. Since the hull is wider than a superjet, the engine bay is so much nicer to work in..My headpipe clears the hood seal area just fine too.
Since I've had my square apart so many times a lot of this is just straight forward assembly. But, I still have a hell of a list of stuff to do. The little stuff takes up a lot of time!
I still have to:
-Order and install lightened flywheel and pole bushings
-seal up starter and stator cover
-finish fabbing up a backer plate for my pole bracket
-install cdi in ebox and button it up
-tap holes in ebox bosses and mount to ski
-install waterbox and tank inserts
-get a new battery(etx9 since my etx20 is way too big for the tray that jeff includes)
-drill holes for pissers and bilge pump
-add turf and pad on top of footholds
-remove midshaft, replace o rings, grease, silicone around the rubber seal, reinstall
-drop in motor, pipe, tank, clamp all hoses, bolt on ebox, etc. Pretty much assemble whole engine bay
So yeah its nothing too big, just a bunch of little things. Should be able to do all that this weekend once I get the parts. Honestly it's starting to get kinda fun.
A DNR service center is right by my school so I'm going to get it registered in the next couple days hopefully.
