Schmidty721
someone turf my rails
- WI
Why not put your motor in your dads ski and have that 62t punched out on a 4mm crank for cheap
What do you call cheap? All I have to lay for is gaskets and carb rebuild kits if I do the case swapWhy not put your motor in your dads ski and have that 62t punched out on a 4mm crank for cheap
Not distracting me from riding at all. Im busy with school.Another three pages of distraction from riding. It's like you don't have time to do things the right way but you have time to do things twice.
And I have no idea what you mean, please elaborateAnother three pages of distraction from riding. It's like you don't have time to do things the right way but you have time to do things twice.
Lowered the attaching point for my trim cable and also extended it out a little so it has a straight shot and hopefully not break as easy. Luckily I had an extra inner cable so I can just slide in a new inner if it breaks.
Yes I could do like your picture. The problem is the method I have to use to clamp my cable down. There's no threads on it,just the housing. So I have to crush the housing to secure it.
That would keep the housing from sliding back and forth?You need a threaded end that the cable housing will sit in, crushing the housing will never work out long term. Something like this:
-Rob
