FPD's "Floatorious P.I.G"
FlightPlanDan
Don'tTrustAfartAfter50
Put it all together monday.
Still gotta pull the e-box for a new pos cable to the battery...but the repair is working for now.
No waves.
And remember; after-work rides are soon coming to a close!
2am Nov 7th. (the night of Nov 6th) DST fall back. :( :( :(
FlightPlanDan
Made a temporary cable from battery neg to flywheel cover.
Solved all starting problems, issues, noises.
Obviously, my ground cable is bad.
But the jumper is not 1/2 assed. It's a good soldered cable.
I'm gonna ride this weekend as is unless somebody says it's not a good idea!
Sanoman
AbouttoKrash
NE Tenn
OK! Fine! l'll be the first. l think it's a great idea.........................
if it get's your azz on the water.
And how is your neck doing?
FlightPlanDan
Installed the JSS modded coil & wires. That part was easy. I figured it was a good time to replace all 3 major power cables. That was no fun. Even with the pipe chamber and fuel tank out.....
I left the head pipe & manifold on. What a PIA.
A women would have had no problem......they are used to using tools in the mirror! lol.
I chose to run the ground cable up the carb side. The original was just about worn thru from the pipe.
Gonna put the lightened flywheel in b4 the weekend. (I'll appreciate any tips on that job!) Just seems like a good time to do it. It's setting there, the tank and chamber are out...
Sanoman
AbouttoKrash
NE Tenn
l used a battery pack impact gun to remove the last couple of flywheels.Worked great! You don't have to own one,just borrow. X2frank maybe?
FlightPlanDan
Flywheel is in. The dewalt cordless impact would not remove the bolt. Used Frank's air impact.
Still gotta seal everything up and put the tank & pipe chamber back in, but should be ready for a Turkey morning ride.
I looked up the torque spec for the flywheel bolt....20 ft. lbs.! I went a bit further than that, but was surprised. (expected something around 70)
Not that hard a job.
FlightPlanDan
Glad it worked out as well as it did! Love to ride with ya on thanksgiving.But l'm gonna be in the mountains....
How's the hand?
I'm also curious why you're selling the stunt hull.
Tell me you're buying a new superfreak!!
The surf report is not good for Turkey day. But I wanna see what these "minor" changes will do. We've all got things to do in the afternoon......
let's see!
