- Enfield, CT
Chris where in CT do you ride?
Dang I never Put mine on a scale and I asked for a reinforced flatwater layup. Oh well, still rips...some thing are better not knowing haha
Im sorry but you pay for a light wieght hull the first thing you do is scale the thing when you get it.
Its like all these guys who buy ADA heads and then dont do a comp test before and after. Well ADAs website was wrong for the kawi 800s and the domes they listed to put a motor at 180 in fact put the motors to 150. SO all these guys but the head bolt it on and make the same power or less than a stock head. You always check what you buy.
ADA specs are with no porting cylinder. The higher the exaust port is raised, the lower the compression is.
No, but im talking on stock sxr motors they are wrong. DO a search there are many cases, and i myself have seen it on 4 motors. This thread is about Chris build not for me to teach you how to order domes from ADA.
I was making the point you always need to double check what you are buying not just take an aftermarket companies work for it.Take it easy bro, its you who start talking about ADA dome, if you dont wanna talk about it just shut up!!
