- Morris Ct
Ill let Brad explain this piece if he wants.
For clarity, which wave do you hit? 1st or 2nd? I have been working on it and hitting the 2nd and having a lot of trouble hitting it right.
Great write up btw! Could you do one for a setup wake for rolls too?
Hit the first wake
Hit the first wake
First wake for sure. But also remember timing the wake is different for every set up. different motor, pump and especially hulls will require slight variations in timing based on how everything reacts and how your motor builds power.
For me to flip off my second wake, i almost have to slow down to a crawl into a tail stand, then flip off the wake from a near stand still. The flip is super tight and fast.
180 hop is the easiest cause it puts your ski into the flipping motion upon landing, practice a few 180's and soon as u land straight just get your timing down.
sikk coupler cover
wasnt expecting this from you turbo, good info. I agree with the 180 flat spin to flip. I'm just shy of 200lbs and this is what I did and nose them in with a stock ignition non ported 718. Plus it's technically a combo. IMO it's easier not dealing with timing and you can concentrate on just rotation and get used to it.
I'm 240 lbs and suck at 180 flips lol! I'll learn them better this coming year. Need to up the combo list for world finals
