Custom/Hybrid Ground up stunt build
chad
I pretty much love beer
No Skywalker ... tis not done . thanks for reminding me...
Ramjet is on his way out to help with motor alignment, and glueing the bedplates in . I worked alot last week so I didnt get much done on the hull , I did Make a new steering plate .
and Had 2 more Exhausts made up (thanks again Kyle!)
I ll post up some more pics later this evening .
Sanoman
AbouttoKrash
NE Tenn
Looking good with the ZZ Top thing goin on! l'll post some pics later,been working on taxes today for the a-holes in DC.
chad
Superramjet , buddy,and Skywalker came out today and helped me with the mounting and alignment of the bedplates. They are mostly tacked with Plyogrip.. once they are fully dried , I ll remove the shims and fill in the rest of the areas with glue then they will be covered with glass .
Thanks alot guys! I appericate your help !!
chad
since the motor was in place . I went ahead and mocked everything up . So that I could figure out where to mount the battery , and find places for the gas tank/waterbox mounts .
I think I will be running the battery in between the motor and tank .. I was able to fit a smaller battery tray there , but now I just need to find a thinner battery. (3 1/4)...
the westcoast water box fits pretty nice up in front of the tank.
Waternut
Customizing addict
Macon, GA
It's good to see some perspective on how the engine actually fits in there. One thing I have to comment on though is holy gas tanks batman! How many gallons are you planning on having in there?
300sx tank looks like the shiz for the Stunt....lookin' good! Keep the pics comin'
Looks like there's room for a battery next to the tank?? (where the screwdriver is in the first pic)
RMBC Freeride
Vintage
Pueblo, CO
Chad, a Jetworks battery is only 3" wide and I've had great luck with them over the years. I bet it would fit nicely in there. Unless you are going for one of the smaller batteries, for weight reduction.
Keep up the good work.
chad
It will hold at least 4 gallons
the battery will fit in either place .. I figured I would try to center the weight as much as possible and put in in the middle
I took a pic with both battery trays in place..
Thanks Neil.. I will prolly run a jetworks, unless I pony up for a Berky batt.
its an old 550 westcoast silencer that I had 2.5 in outlets welded to and added a water inlet. I tested it on my gp800 stuff and it really quiets it down without killing power .
