#ZERO
Beach Bum
- Florida - U.S.A.
A stock stroke big bore with Northwest sleeves would hit a lot harder than the Group-K 845 IMHO.
It appears they're using flat top pistons in the 88.5 and 89mm sizes very similar to the Riva flat tops made by Wiseco. They have a lower compression height which raises the port timing and when combined with the 62T cylinder it makes it even higher and more suited for racing.
Jared, the exhaust ports open right at or before 90-degrees because 180-degrees would be at BDC. :hitwithrock:
I've rarely seen any skirts bending inward on Wiseco pistons when the clearance is set properly, but I've seen a few new pistons having different measurements even with matching serial numbers. Also, I've seen some Wiseco domes collapse in the center area from overheating.
A new style Wiseco 83mm piston weighs approximately 332.5 grams and the older ones in the same size weigh 350.8 grams. The newer wrist pins weigh about 83.8 grams and the older ones weigh 59.4 grams. Also the newer style KD rings are 1.5mm thick compared to the older TD style rings that are 1.2mm thick.
They must be using some different alloy composition during the pressure forging in a mold to make them lighter and stronger; however, with the overall weight of the complete assembly, they now weigh more!!!
