Idok
F1pro
- Nations oldest muthaF+++kin city
Nice Ski! So to clear things up all there poles now come black powder coated(from what I heard from XMetal) but, I also heard that they do not hold up well in salt water for very long? So is that under their warranty?
the powdercoat will not likely be covered under warranty....its just one of the downfalls of ANY part that is powdercoated in the ocean
Spring? I thought your not suppossed to use a spring. However, if you did do you use the stock one because the pole is lighter or would you still need a tighter one?
why are you not "supposed" to use a spring? you can do whatever you want..some like a loose pole, some like it stiff....
personally, I like a "floaty pole"
