chriselmore_1
high on resin
- san jose ca
What is ff
ohhhhhhhhhhhhhhh. Nowwwwwwww I understand. I felt like the guy who gets a text and has no idea what all the acronyms mean. Makes sense.
Kyle has the talent to figure out what is wrong with it and between him and Dan, I have confidence. Too many of these motors are in service, relatively, to all of a sudden have problems, two years after the first one goes to work.
My feeling is some of issues might be the pump/impeller combination's are too small.
Might need a big pump and a big wheel to hold the motor down and let it move some big water.
Brian
OK, I've always been very straight forward when I see postings that do not make sense to what I found to work and not work.
Even if my comments have to be made to a competitor who posts here also.
Be careful with this info...IMO, this is not necessarily a true statement.
Here is my reasons why...
I do believe that both of these engines are running PFP dry pipes, so I do agree that pump setup is very crucial.
Most engines of this caliber run MSD-TL or some form of programmable ignition curve settings. These type of engines can and will detonate running this PFP dry pipe if you go too big of pump and too big with impeller pitch.
When you do this, the overloaded engine will not accelerate well and reach peak RPM's verses the programmed timing curve. In other words I'm saying the engine is being fed too much load and then the RPM's are down and the MSD-TL or other RPM based ignition curve settings are not retarding the timing to a safer level to prevent detonation.
When a pump and prop combination is too small, the engine will overpower it and cavitate and see no load hence rpm's will be higher, then the ignition will retard timing more with the added rpm's which in turn lowers the chance of detonation occurring.
IMO, I'm backwards as to the statement Brian made.
P.S. I have done this to several engines and have learned more about the setup running this high horsepower PFP dry pipe. (it's not very forgiving like a factory 'B' wet pipe)
what was the verdict on the motor?
The jist of the engine problems were the porting was off on the bottom of the exhaust and the piston skirt was also "catching" on the downstroke, it was real close to freeporting. Kyle took a spare top end with him and exchanged it. Went over the setup and tuned the boat.
According to Kyle, he seemed really happy with it now.
Brian
that's some great customer service right their!!
Yes sir, I wish it were right when it went out the first time, but it happens. At least it is right, now, and he received some in-person tuning.
Brian
I M VERY HAPPY FOR MEUCERANGO!
but .... for me what happen ?
I HAVE ALREADY DO THE MACHINING, i have put the two new wisecco piston!
but i don t want to broke again!! like meucerango ....seven pistons:scared:
what dasa can do for me?
THANKS
BETA FROM FRANCE
THANKS
BETA FROM FRANCE
