- ARGENTINA
But what fuel are you using?
__________________
98 oc
__________________
98 oc
comprecion is the ratio of 14:1 (38cc dome 534cc)
38cc dome I have 180 psi
42cc domes with respect to psi (160 150 140 ?????)
you could be right there chucky
its hard to tell from the pics and something i seem to be doing is sending me blind
Personally I think this engine needs to be sent home so they can look at it correctly and not in fuzzy pics on the internet
These are some of the issues that are your problem...if the squish is correct, rave valve has to proper clearance, and exhaust port is chamferd enough for the rings not to catch the port.
Compression ratio could be to high, too much timing, not high enough octane fuel, add 1/2 cooling lines, with extra piston clearance.
Carbs are too small and also could be to lean, pump not setup correctly to match engine setup.
This is a common problem when engine is not setup right.
I dont doubt it ChuckyI know the reasons why this happens to these engines...been there done that.
the last four pistons in use with gasoline 98oc + octaneboost
same piston destruction
U might try Red Bull,
