HELP¡¡¡¡ DASA 16 mm
They would, if he would call.
I wish you would have asked these questions when you bought the motor, or 4 pistons ago.
You crashed 5 pistons? Meaning you lean seized them? Or the timing isn't set right? I know of noone we sold "5" pistons to. Who are you getting the pistons from? I SERIOUSLY hope you aren't using "off the shelf" pistons because they will "CRASH" the dome.
Are you sure the compression is 180?
Did you buy this engine from DASA or a dealer?
Please call the shop and ask for Kyle and we will get your setup worked out.
Brian
light pistons an sleeves 0,009 inches
squis 0.03 inches
Meucarango...here is the deal. If you want a baseline correct jetting spec for that motor/carb setup call Kyle at DASA. Dial the us code and 951-697-3441.
That will be a good place to start, but fuel is different all over the world. I don't have any direct experience with taking my own equipment from here and trying to tune it for Argentinean fuel. But I have a friend who bought a boat that was set up to run on fuel here, and it was way too lean using the fuel in Argentina. And when I have brought my motors to Brazil, I always have to richen them a little.
My recommendation to you would be to get a good baseline setting from DASA, and jump on mundojet.com.ar/ to find someone in your area that could help you dial the boat in. It is never as simple as just installing jets...
Again the easy way is to take it to Maxi...or another builder that you know and trust.
Again the easy way is to take it to Maxi...or another builder that you know and trust.[/quo
ok I am going to call to kyle ,thanks ross champion
FRANCE
FOR YOUR PUMP YOU MUST INSTALL 145 SET BACK PUMP SKAT TRACK WITH 14 VEINES, skat trak don t make bigger
on my dasa +16 WITH TWIN 48FS NOVI , i have this set up CARBS:
low 110
HIGH 130
2,5
115 SPRING
AND IT S GOOD WITH 12,8KG COMPRESSION, with 90,5 MM PISTONS
GOOD LUKE
low 110
HIGH 130
2,5
115 SPRING
GOOD LUKE
OK¡¡¡
THANKS FRIEND, VERY GOOD DATA.:arms:
GRACIAS AMIGO¡¡¡¡
Pics
:brap:
This is my engine when I received
Today is broken, then upload photos of broken pistons.
More pics... crash pistons
:crying: :splatt:
