I dont care for the Xmetal Trim in the fact that you have to use a silicone hose and constantly smear KY or Vaseline on them.........
their was not enough room on the top of pump to top of hull so the arm hits the hull also the cable was so kinked to get it hooked up i had to return <got a thrust !i realy liked the rrp but just would not work! but their mite be more room in the 50 cal pump area not sure!What wouldn't fit?
yah break the grinder !hahaJust cut a notch in the tray..lol
i think you will spin that prop like a top with that bigger motor you are using! i had a 701 ported in my predator and ended up spinning a 9/17 we ended up with a 12/18 need to remember your ski is shorter than most! like to see how it works though!
Yes it requires a silicone hose to work properly but i usually just smear Vaseline on it right before my first ride and never touch it again after that. @Yami-Rider uses something else I think. Never been that big of a deal for me. I only use trim for setup wakes anyway. It's the increased steering that I like and it will spoil you.
