- Tuscaloosa, AL
can you come clean up my freak some??? that is perfect.
stay with the 205 i have tried a bunch and all others i used caused some cavitation or would not load the pump good enough on the krash!this did the best for my ski
@chixwithtrix Before you install the pump! Make sure to seal around the cooling lines, and trim/steering cable outlets with 5200! My surf hulls tray already has water in it...Well removing the old stuff was a pain in my non existent dick. Is this prepped enough or does it need more scuffing?
@chixwithtrix Before you install the pump! Make sure to seal around the cooling lines, and trim/steering cable outlets with 5200! My surf hulls tray already has water in it...![]()
So many parts so little time!
How do you bore the shoe out? Use a Dremel and slowly grind away?
I used a die grinder with sanding drums. Took me about a hour to get it perfect
Sweet. I thought the cable bolts to the top of the reduction nozzle some how.
Are you going to have the duct shoe bored to 148? Surprised there's that much clearance on the shoe, usually have to grind alot to fit.
I just got a JD shoe. If you bore it out to 148 the inner ring will be gone.
