*** Ride Report ***
Finally a ride report, I wasn't able to have it finished for the Torch Lake Freeride but I was able to finish it while on vacation up there. Kinda threw it together on the beach so the BOB pods are just bolted threw with some fender washers and rails are not turfed, but who cares about that.
Anyways a couple things that I have found
1. Cold Fusion steering DOES NOT work with the new X-metal adjustable pole, the bushings supplied are a larger OD diameter then the ID diameter on the pole, it required turning them down to fit. Also the turn plat is too large and it hits the stop, I had to turn the bar stop down so the turn plate could freely move.
2. There is no way RRP riser bars will ever fit the stock X-Metal chin pad, so for those looking to run the riser bars with this setup watch out! I still haven't figured out how to make this work, cause I was told it would all work.
3. spoiler alert....REINFORCE the shiz out of the pole mounting area and use a limiting rope!! lol.
Anyways...First ride out felt pretty good, a little nose high a slow speeds but with the blurp of the throttle and up to speed it came down and rode pretty good, very maneuverable and short small waves would easily launch the ski with no problem. The rockered nose felt good and didn't want to plow thought the waves it want to run up the waves.
Frist ride out was short lived however hit a wave or two and lost the steering...back to the beech to find the steering came undone, a little adjusting and I was back on the way. Next ride lasted longer and I was able to spend a little bit of time trying to learn and get used to it felt good but is definitely a learning curve to get used to the short hull but I liked it. Had a couple of other riders take it for a spin, hopefully they will chime in as well....ahem...Jordan.
At the end of the ride went back to shore and assessed the damage and found some good cracking around the pole area enough so that it was not ride able for the rest of the week. So needless to say so added reinforcing is in order, Version 1.0 (learning curve) I’ll keep ya posted on Version 2.0 lol.
