Kind of in a holding pattern waiting to get more materials to finish the tray and get the exhaust tube bent. Decided to use some left over poly glass and filler to make a mold of a coupler cover so I can try making one out of carbon.
I used the same process as I did with the ride plate, but I wasnt sure if I wanted to try keeping the bushing holder. I ended up incorporating it and filled in the ears so the final piece is at the right height. May have to ditch the bushing holder later, I know it will be tough to get the matetial to lay in the tight corners.
