I ran out to check on the ski this morning before work. It seems to be very solid, the sides of the engine bay had a lot of flex before mainly along the top deck, but I cant get any movement out of them now. I started out with the 2 layers of biax over the motor mounts and under the pole bracket area and a layer over the bulkhead then added 6 layers to the very front of the nose, 2 layers over the rockered section followed up by 2 layers on the bottom from the nose to the bulkhead, 2 layers along the sides and then 2 layers of carbon everywhere. I think I over shot my weight goal by quite a bit but I figured Im better off overbuilding it so I dont break anything. Im guessing I will be in the 100-110lb range once its done but we'll see.
