superjetjames
superjetjames
- Three Zero Three
Here's mine.
Here's most of what's been done to it:
61X Cylinders - bored to 83mm and ported
62T Cases - ported and epoxied
Riva Girdled Head with 31cc domes
Factory B pipe w/Mod Chamber
Dual 44 carbs with stock reed cages and Boyesen Pro Series Reeds
MSD Enhancer (soon to be Total Loss)
Static Timing Advanced 4 degrees
Dual Cooling
Impros 12/15 set-back Solas Prop
85mm pump nozzle with a Wet Wolf Freestyle Cone
Sides and handle pole area reinforced
Custom Footholds
C.A.T.S trim system
Front Exhaust
One-Way Drain Valve
Blowsion Shortened Turnplate w/UMI bars/ODI Ruffian grips
New Hood Liner with Handholds
Handlepole breather/drain
Is this Glen Glorioso? (not sur on the spelling)
It has been a long tim since 2000 miss seeing you @ the Races!!!!
