you can absolutey tell the difference between a pro built motor and a home built motor...EVEN WITH THE SAME PARTS!
Yup. :biggthumpup:
You just don't realize it UNTIL you have a pro built motor.
pretty sure the prices are approx this for a ss 865
kit - $3100
m/c & assy - $700
oem case/crank - $1500
oem seals & other parts- $200
boyseen intake/reeds/mod carbs $1500
flame arrestors $150
so thats around $7150
the team scream modded b-pipe is around $900
then you need your bed plates, electrics, flywheel cover
just to give approx $$ values
no fear of them here, either...
I couldnt even tell you how many motors the crew has built here.....
20?
30?
proably more...
we have a boremaster in the garage..........
these are not stock motors though....big HP motors are different
custom squish
big pistons with tight tolerance
special cooling designs
Ive said it before and will again..
you can do it for much less. the kit is 2800, chucky says you can bolt a b-pipe and all the rest of the stock parts on to your motor and just use the kit as an upgrade. Obviously that isn't optimal but you can build from there.
Damn these options are excellent and this will be hard to decide.
You guys saying you can tell the diff between the exact same parts assembled by a pro and a rider (that has built motors)...I just don't buy it.
You bore a cylinder to the pistons specs.....you assemble the motor properly...easy. Again...assuming the squish and all the details (cooling line routing etc..) were the same for the pro builder/rider builder. It is just parts and gaskets and wrenching.
Tuning on the other hand...sure a builder who has tuned the same package/packages dozens of times will tune it better/quicker.
I am really digging the kit price of a "upgrade" 865 and I have zero worries that I will assemble anything wrong and if I did I would not be one of those jerks blaming it on the guy who sold me the stuff. And I am not worried about the tiny tiny bit of power I would lose by not porting my cases to the point of needing epoxy....a little porting is fine.
But if I did decide to drop 7600...DASA is getting my money. Full billet ported motor with no epoxy! But that prolly ain't happening because I'm guessing with carbs a person would be approaching 10k and I could never afford that no matter how much I love this chit!
pat told me that when they assemble they do some extra "stuff"
but hey if you think you can assemble a team scream or dasa motor as well as the manufacturer can then go for it
i know i couldnt
the stuff is case porting and intake filling. you won't know the volumes they use to make it work as well as they do.
WHAT!? Dude I have gotten 10 years out of 2 motors and only replaced one front crank seal. And the only reason the first motor went is because I sank it in Daytona and then came home to a blizzard and let it sit. And even then I used a mallet and a piece of wood and some PB blaster to get the pistons moving and rode it another 12 tanks of gas until it blew.
I have never in all my years heard of anyone preemptively replacing crank seals every year.
I am worried about epoxy because as I said I have seen it deteriorate and need picked out and re done....and I ain't buying a 5k motor with epoxy unless I have no choice.
OEM cases are forever.
what!?!?!? that is insane............. who told you that???
get over the epoxy....if it had been done by someone reputable and failed you might have an argument, then you'd have to reverse engineer to see why failed...
materials or prep..
I'd bet on prep 99% of the time...
ss 865 kit..start at the 2nd bore will get you either 847 or 849 with 1 bore left.....in your ENVY hull it woudl be absolutly nutz, boat wake backies woudl not be a problem
I belive I read that TS will also be offereing half-sizes in the near future as well.....more bores!!!
I could not justify buying a 5k plus motor and not taking it apart etleast once a year to make sure every thing is working as it should and replace all the gaskets.
Just my thought...
Then again maybe your 1 northern season is like 3 fl seaons...lol
I have 11 months on my TS motor.......probably well over 150 gallons of fuel
the spark plugs have been changed ONCE..and thats it
