So while I had the pfp out to patch the breather holes, I decided to pressure test it. The seller seemed like a good guy and is well known and competes at the pro level, so when he sold me the pipe a year ago I took his word that everything was in tip top shape. I knew he had patched a leak, but I never really examined the patch job (that's on me). Turns out he didn't have it "welded" he had it "jb welded".
I connected two of the outlets and blew into the other and sure enough air is leaking from his patch. I gently tap it with a flathead and it all falls off.
I tried to "weld" it back together with my Mapp/oxy torch (let's be honest, it's a fancy flame glow lighter), but that just made the old weld material separate from the metal even more. So this is what I have:
Besides sending this off to someone who can weld aluminum (trying to avoid that), what can be done to remedy this?
Honestly I'm finding out this whole PFP was a huge piece of poop and I should have examined it closer when I got it. If it wasn't for the year it sat on my shelf, I would be hitting the seller up for my money back and/or adding to the negative feedback forum. I think I paid $1k and it had a broken flow control valve, no couplers, clogged filter, clogged jet, jacked up waterbox, and now a ghetto rigged up patch. Not exactly the deal of a lifetime. Anyway, end of rant. Suggestions??
