I have a few things I want to modify already. nothing bad just small things that will make life easier or improve the hull.
the reason I did the plate that way was it makes it so much easier to change the length of the hull. the other reason is that it will allow me to make changes to the plate and not just the small area that used to be the plate, now I can modify it over the whole back end of the ski. so any shape that you want to carve out of the bottom I can make a piece that will lay in the mold and its basically that easy. if it needs to hang down lower that is where I would have to make a new mold.
as far as making a JD plate I wont do a direct copy but I will make something that approximates it. I have a wide selection of skis and plates and have some ideas on some things I want to try. One of the problems with that plate is it interferes with the nozzle, I want to make another plate with 2 cones in it, I have some other shapes that I want to try out as well.
this hull was built around a stock hull. that was the plug and is the green ski. it belongs to Chasingdaylite(Pat)
Pats new hull is all carbon and we modded the top at the gunwhales because its something he wanted. so right as we were about to build it we cobbled together some inserts and made it happen. this is the orange and black
after his hull was popped we were kickin around the idea of shortening the ski. actually we had talked about it previously but since the molds were made it was not really an option. I sorta pushed him to cut it up after we agreed on how it could work. after seeing how it was actually fitting and how the rideplate was mounting I knew I had to find a different approach.
So I molded the back of the stock fx and made inserts from that to install in the molds. I have a few more tweaks to do but considering this is just something that I wanted to do at the last minute I think it couldnt have gone better.
Now is the fun part, getting feedback and seeing what is working and whats not. The green ski is a blast to ride but its also much heavier than the new version. its also stock length. so it will be interesting to see what actual riders can do with it besides putt around in circles like me lol.
