Not sure i agree with that water routing
Parallel cooling with a b-pipe and 2 into one out the head, haven't seen that to much, how you like it ? Have you temp tested the engine and what's your water temp in the lake ? After break in my buds is running cool, parallel might be the way to go for him too
Your cooling set up looks most ideal imo, pressure for the pipe, and single cooling for the engine with one pisser so it's not being over cooled. We're working on getting our engine temps up, the true dual cooling we have with 60/65 degree water is to much cooling. might switch.
Do you know your engine temp
meh, too late for all that lol. My setup works well, and I kind of like having one pisser for the motor and one for the pipe, so I can tell which one quit if one ever decides to quit.
I dont know my engine temps, but I guess I could get a couple of those temp strips and check it out.
I think you're sacrificing power with your current setup.
You can run split cooling or traditional. Only difference is your not preheating the water before it enters the pipe. I have ran both, both work. I ran it with great success in my Stock Class SXR.
