My 97 SJ Motor build 85mm Flat Top*Done and Runs!!!*
BROSS
The future right here
Lake Norman, NC
The companys name is HM Elliot Coatings, in Mooresville, not shure on the web site. He was Rusty Wallace's Head engine builder in the 80's and early 90's, he's been coating since 94 and does all my dads pistons and bearings everywhere he worked. He came highly recomended.
BROSS
Lake Norman, NC
The cylinders are in my hands and WOW what a piece of work, Tim your the man, fast shipping, 2 month turn around, not to bad. Now just waiting on the girdle kit from blowsion, should be here next week.
BROSS
Lake Norman, NC
As luck would have it, I assembled the motor, purrrdy at that, as I was checking squish I found a bent rod, could not believe it. So now the motor has to come down and a new crank is on the way. I'll get a pic of the engine before it comes down. thats a real :nutkick:
DAG
Charlotte, NC
wow that sucks, at least you found it now than with the new goodies inside. must not be bent bad, 1/10mm???
is the bent rod going to effect your flywheel balancing act?
BROSS
Lake Norman, NC
The squish was off by .008 from front to back, you can see the pistons to one side of the bore, still went together ok, I'll get a pic of it. The front cylinder had .035" squish, even. No to the balancing, the crank end I cut off a bad crank and my dad trued it before starting.
#ZERO
Beach Bum
Florida - U.S.A.
Never mind they're a bunch of porting pictures on the Judge Motorsports web site. :grumble:
When some advertizes porting it helps to see some of their work because you can usually judge how much effort and time was spent.
BROSS
Lake Norman, NC
Here she is before the tear down:261:
No pic of the bent rod.
BROSS
Lake Norman, NC
Well I got a new crank from Riva, Trued and welded, not cheap. I got the motor together and checked squish, its a little tight at .035". TJ said I might be able to run it but dont over rev it!! I think I may machine the domes to get .039" to .040". I'm waiting on the hood and battery box anyways. I have a hood if I need to borrow one to ride, still looking at a week or two. Pics to follow.
BROSS
Lake Norman, NC
Update time, just waiting on the battery box and fuel pump bracket, oh yea the hood is still at the painters...
