Love that color! Great choice!
Lookin good Bobby,I'm glad to see your'e taking your time with this build. I can't wait til the Spring thaw, I'm really itchin to try out my new setup too.
Badass!! cant wait to rip it with the 701 and teach you how to launch those 180 stabs!!
you should have asked me about that hose, I have two in stock that I can't use with my new waterbox.Today was good and bad. I am a teacher and we had a snow day which is good because I got some time to wrench on the ski. The bad....there is snow on the ground and the lake is still frozen over =[
Anyway....i got to spend a little more time getting the engine shimmed correctly so the couplers line up perfect. I was also able to get my first mockup done for the engine compartment. Im glad I was able to do this because i ran into one problem...I bought the wrong coupler that connects the waterbox to mod chamber. Apparently I missed the fine print on xmetals website that said the coupler is for their stinger mod to the chamber so one end of the coupler is larger than the other. I assumed their waterbox just had the larger end. :doh:
Other than that, the mock up went great. This mockup was so much easier than the Q8. I cannot believe how spacious this hull is.
Here are the pics...
The hull has 1/2 in fittings from the pump to the engine compartment. I installed 1/2in fittings on the solas pump so that problem was solved. On the engine side, the manifold and head pipe have 3/8 fittings. I ended up finding some brass reducers and made some small conversions on the inside of the hull.
Is that a New B pipe or did you paint it?
Wow tons of room in there bud! The q8 wasn't too bad, just the alignment was funky and there is a certain order how things had to be put in. Funny thing I did the same exact thing with the 1/2 to 3/8 reducers. Why did you go with some monster carbs for the 701?
Setup looks clean but i highly recommend putting it in some sort of enclosure
JSS's work is always topnotch. ^^ He's got a point. Is this thing gonna see any salt? I run mine in the open like urs but I'm 100% fresh water. I'd def invest in a closed box if I ran salt.
