Got a little more work done. I was dreading glassing the inside of the nose, spent the whole day doing it yesterday, glad that's over with. Went with one full layer from hood lip to nose, 3 more layers from lip half way to nose, 3 inch strips over the relief cuts and one additional 3 inch strip on the lip. All in 1708. Instead of wetting it all out on cardboard beforehand like last year, I tried wetting it in place as suggested by uscomposites. Cabosil in all the low spots and V'd out cracks, wait 2 hours, paint tack coat, wait 30 mins then lay glass. This method took a lot longer, especially in the tight spots inside the nose, but I'm sure it saved some resin waste. Ended up using about a quart on 10 sq. ft of glass. Covered it in wax paper, babysat it for a couple hours pressing things back down. Hopefully it will be pretty bulletproof now, I'll still use the top and bottom bracing plates though.
Got the pump rebuilt too, pressed it apart at my buddies place and used the freezer / torch method for assembly. Cleaned up the stator veins with the dremel. Packed the bearings with some M1 synthetic grease that I had on hand, should be good enough. Found out 2" pvc fits perfectly on the bearings to put it in the freezer. Glad I had a socket on hand when putting it together. The rear bearing and entire assembly needed a few love taps to go together. Thanks
@john zigler for confirming the seal orientation. New wear ring and hooker 9/15 from
@JetManiac. That thing is about as close as you can get to the stator section.
Now that hurdles out of the way, I'm hoping for a test ride next weekend. Still need to epoxy / port cases, paint cases / cylinder, powder coat fw cover, bedplates, ebox and b pipe then put it all together.
