Ericfox
Do it twice?That's DooDoo
- Akron area --> OHIO!
might be a good pipe for eric malones engine, but not as good as a b-pipe for a stock or slightly modded engine.... or am I way off....
Fox, you are dead on............ stock to mild stay with the B Pipe, but if your running a Big Stroker flat top or a Lamey, then this pipe would have potential
on a stock to lim engine...woudl the Bpipe and the malone pipe be approximately equal?
or will the bpipe outshine it with a limited setup.....
The pipe isn't even available yet, and even if anyone has a prototype, do you think they have tested it on enough varieties of motors to be able to answer that?
:AR15firing:
thats pretty much the same answer Pat Bogart gave me not 2 minutes ago :clown:
Wait just a second.... EME boats use POLARIS based engines. Are they making a yamaha version of this pipe, too??
If you look at the Polaris Octane (and the EME motors) they use an adapter plate to allow them to run a standard, off-the-shelf Yamaha exhaust manifold (well off the Factory Pipe shelf). So, if EME builds it for Yamaha 61X/62T-based motors, it will also work for their Polaris motors (using an adapter plate).
just want to update all i have to say is UNBELIEVABLE !!!! We just tested the EME superjet pipe on a 5mm lamey with single carb and i would say min 25% power increase . Did i say unbelievable . I cant wait till this product is out there . This will be the number 1 bolt on item availble to modified superstock type engines . We have yet to test on other engines which I know others are wondering but we will keep you posted and i will show pics at the end of are testing . Great job Mark on the pipe
this will be a bit before you see it available to the public due to alot of tooling and so forth to get it done the right way . but it is the answer alot of guys are looking for .
