masterblaster
X-H2
Foam has little effect on rather it would back flow. The diff in height it would float would be minimal. The issue is the height of the waterbox and exh tube exit. When you move ski in water without it running
When you put the life jacket on, you increase the volume of water being displaced, with almost negligible increase in mass.Speedy's post made me wonder, So I studied flotation and bouncy for a 45 minutes this morning.
I learned about density's and specific gravity and that an objects density in comparison to the liquids density its in is what produce flotation, not the objects weight. Some of its in #236
If I get in the lake and float upright and mark the water level on my body it prolly be around say the middle of my head. Now if I put on a life vest and took another measurement I would find I've risen out of the water dispite the weight of the foam in the life vest, positive bouncy
Am I missing something here?
Phew, good! No more fluid dynamics lessons for today!^^^ Owe I get it put that way![]()
What?Sound good on the surface but I disagree
Most foam used in this application has a positive buoyancy and it's density is less than water, floating itself and adding some floatation to whatever it's attached too....
The orange bowling ball weighs 8 pounds and has less density than the water so it floats
It's not about weight, it's about density's
The foam isnt touching water its being added into the ski.. the ski will displace more water with the added weight of the foam.Speedy's post made me wonder, So I studied flotation and bouncy for a 45 minutes this morning.
I agree with Speedy. In order for something to float, it must weigh less than the water it displaces.
this is the real issue,you could have foam or not and it wouldnt make a diff,the inlet height of exh tube and water box height plumbing meeting it is the issue,id like to see pics of the hulls having this issueSo back to the water intrusion issue. On my hurricane the ex tube running through the hull goes through the bulkhead at the highest point possible and exits at the lowest point possible out the back of the hull. And it's a straight tube with no bends. No foam in the hull either. So the water has to climb up that before it gets to the water box. I normally launch and pull the ski with a bigfoot tote. When it's sitting in the water it's on a stand. This topic does worry me a bit, but I still haven't had any water intrusion.
I think you guys are right on the hull designs as far as ex tubes go? Def worth looking into.
