Freestyle New Thread - My Superfreak with TL is not running good! Help!
BrightE's
Paul
Seattle, WA
My plan right now is to isolate the metal coil via a rubber sheet, and nylon washers, and shrink wrap around the bolts. I'll check back in once it's all locked in.
Pablo
sqeez bth levrs & lean bk
georgia
Good news man. I ground both of my MSD coils independently to the engine with thicker gauge wire. Never had an isolation problem.
BrightE's
Paul
Seattle, WA
Sent from my VS980 4G using Tapatalk
good to hear. whats weird is i am having a very similar issue with my ski right now. runs fine out of water, but when its under a load, its like its only firing on one cylinder.back fired a little bit also. i have the old 4270 analog setup. 3rd season on this TL setup. i have an extra coil i think ill try. or maybe its the brain.( i removed my whole motor thinking it was reeds or a carb issue also!). good job sticking with it and getting it fixed. theres nothing like the feeling of fixing a frustrating perplexing problem. i bet you feel like you could fix anything now!!
