ATS_Aaron
X-
- Shady Shores, TX
You are totally right. We're are going to need a miracle prop. Basically a prop that will work to not seriously bog down a 70hp stock ski and still not break free/cavitate a 110hp modified ski.I thought the problem with NOS is the pump. I can see if your only going for topend speedrun but then the boat will be slow out of the hole. Do you plan to prop just for top speed?
The current 13/17 3mm cutback Solas stuff isn't too bad, and seems to be used by everyone from a stock 701 up to a TS 828 stroker.
For those of us going for a reasonable 25-30hp boost I doubt it will be an issue. Guys trying to get DASA performance out of a stock 6M6 are going to have a dog of a ski off the bottle.
Aaron
