Progress: I ordered jets and a new WOT switch for my nitrous kit. We managed to get it "installed." I put it in quotes because it looks like total crap right now, but this is all being shoved into a $500 6M6 squarenose for now.
We were all excited about lake testing, but then found out my starter wire is corroded. I can't get to it with the (stock) exhaust on the ski. Hopefully I'll have time to fix that today, but we have a customer car we need to get done before tomorrow so we'll see.
We have the Wide Open Throttle (WOT) switch mounting figured out for stock Mikuni's with the stock throttle cam. Cabs with the aftermarket throttle wheel will take a little more work.
We also have tested the fuel enrichment and have 5 psi of fuel pressure available for the nitrous mixture. We'll see how that goes in actual testing though.
We started with a 6M6 because I have a bunch of just 650 parts that I can use up if necessary. The principles are the same on 650-1000cc engines.
We have a 20oz bottle bungee corded to the fire extinguisher for now. the 20oz bottle should be good for about 40 seconds of nitrous at 25hp. Considering we are using this to jump wakes/waves that is probably 10-20 good hits. The 40oz bottle will deliver twice the fun.
Bottle mounting options: the 20oz bottle will fit under the hood easily on a 6M6/61X however I am not planning on making custom bottle brackets for that.
The 40oz bottle will lay sideways in the tray just like a SN had it's fire extinguisher. the extinguisher will have to be moved under the hood.
Bottle filling - a trip to the nitrous store everytime you want to ride kind of sucks. We managed to pull of a successful syphon transfer yesterday and fill our 20oz bottle from a larger 10lb tank that I had left over from car stuff. the 20oz and 40oz bottles could be removed and filled pretty easily at the lake or on the beach.
Kit prices are projected at:
6M6/61X (or single carb anything) kit $499
62T/66E kit $599
The kits will include 2.5lb bottle (20oz bottle will save almost $50 if you want to stay small), 2-3 sets of jets (most likely 13 hp, 25 hp, and 37 hp), bottle brackets, solenoids, wiring, WOT switch, arming switch, nozzle, steel braided teflon line, solenoid bracket(s), fuel line, etc.
The 62T (basically any twin carb engine) is higher because of the additional nozzle, jets and lines.
I'll check on prices for a larger bottles to be used for convenient transfer filling.
Aaron
