jetskiking
Im done sanding!!!
- Dallas Georgia
If its a stock CDI then the manual has resistance values for different wire combinatoins in a chart. If its a MSD replace it with a known good one and see if the problem goes away
I been trying nearly everything that has be listed, that most have agreed on. havent pulled the motor if thats what your saying???????????????jetskiking said:Running the motor with one of the plug wires off is not the proper way to troubleshoot a the cylinder. Listen to what everybody is telling you
I AM running different pickups for each cylender... THIS MAY BE IT!!!! i cant beleave this dident cross my mind to be the 1st think i looked at!!! :bad3: :banghead:Matt_E said:Grif: Your fuel pickup tube for one carb may be at a different depth in the tank than the other (if it has a seperate tube for each carb). If so, you could get water in one, and not the other. SO.....:fingersx: back at ya.
Granted, a properly setup dual carb setup will have both tubes the same length.
Just saying, it's possible. ALso, one carb may be locked with water.
Just drain that tank. IT's easy.
ArtMaybee said:Get the cheap plugs...
Those Iridium plugs are not the best to run in your ski.
Just read the first post- he has dual 44'sMatt_E said:Not necessarily. The stocker dual 38mm carbs have the throttle drum on the front. The single carb has it on the back.
grifnasty said:44s with 46 mani and cross over is epoxied
ski4 said:my riva manifold would put the throttle up front as is the stock manifold i am rinning now
SJ/XPBri said:when you pull the cover the parts will not go everywhere. The fuel metering side (the square cover) will only have a spring and diaphram pop out.
