wydopen
onthepipe
- Goleta the Goodland
if you dont have your steering setup for maximum throw it dosnt even matter cause u arnt using the entire amount of cable throw anyways
Mine turns the same both directions. I started by centering everything first, then adjusting the ball cups. Bars, cable and nozzle centered first. I've seen guys with their cable not centered and either not having equal throw and, or breaking the cable.
see quote above..
once u have the ball moved as close as possible most likley the threaded extender will hit the cable sleeve before u hit the steering stops...you will just have to see once you get it setup...sometimes on those trim specific nozzles you dont have to grind the backside because its already flared to accomodate the trim ring..once the cable position is moved make sure the back of the steering nozzle clears the reduction nozzle so it goes from lock to lock on the turnplate
