- Atlanta, Ga
Good thread
The extension box makes a hull handle "longer" than it actually is, it gives more leverage on the bow of the boat to make it handle flatter, they are trying for the opposite effect than most of us are, if there nose is pointed up, they are losing power into the water. The same would go for turning, the boat would have a larger turning radius the further out the back the drive is. I would think (for a freestyle application) the closer to the center of the ski that you could put the pump/outlet (while still maintaining rideability) the more effective it would be. If that is right, it would seem you would want the trim nozzle as short as possible as long as at full lock none of the outlet diameter is inline with the reduction nozzle. Right? This is also a double edged sword because the further back the pump inlet is, the longer and better it stays hooked up.
Setback pumps and long nozzles come from race roots.
that precisely what i was saying.
Haha exact same question I have. I've been eyeing the ATP nozzle forever now but waiting for somebody to give direct feedback on flatwater to make the purchasethis is a great thread.after reading,i modified my steering nozzle(62t) and adjusted my cable.now i have ALOT more throw out of the nozzle.and im thinking the 62t nozzle is a short one which will result in tighter turns(better for rolls).but im curious...i read the whole ATP nozzle thread and im wondering what makes it so special? length? placement of the steering cable ball joint?
Here you go. it takes a 10mm metric bolt
