Phantom Resurrection
Was gonna say put down the pipe and go to bed when I saw the first image of that hot mess of a fuel tank install.. Glad I didn’t, after your next coupe posts, it looks very interesting, very creative sir, I like it!
Put down the pipe after the fuel tank install ? I figured you'd of known I was on the crack pipe after the first post when I said I WANTED to do turf !!! Lol.
Thanks !!!
CD155MX
Squirrel!!!
Alta Loma, CA
This build has some really cool ideas I may steal in the future. Level of quality is inspiring. Makes me feel like a bit of a hack. LOL. Many thanks for sharing!!!!
Thank you for referencing Rotaloc inserts. (I just received my @tom21 bolt on front sponsons and was thinking about glassing in some nuts on the inside of the hull to make installation and removal easy.)
Thanks E !
Just went thru this whole thread and all I can say is wow!
Thanks B-Dude !
Amazing job! And some great tips!
Thanks Quinc!
all of your work looks fantastic. i really like what you did with the inserts. my freak hull is going to need all new inserts i really lke your idea on that.
Thanks Fast!
The attention to detail is amazing! Love your work.
Thanks AAlamo !
Thanks CD !
Yeah man Rotolocs are amazing. I've ground out many different types of inserts but the one thing I've noticed is even a poorly installed Rotoloc can put up the best fight when it comes to getting them out. The downsides are they're thin. Not a lot of thread area. I made up for it by going wider (M10). Stainless bolts in stainless Roto's can be easy to gall, another reason I went with bigger more course thread. Even with my studs I still hand cleaned the epoxy cover with hand drill. And a rethreader, NOT a tap. And compressed air. Thread etiquette is crucial. It would be a mess to grind one out that is galled. And I always put set screws in them when I'm in a build to keep em clean.
That's why I post em. If it gives you an idea or helps you out just be sure to post pics ! Thanks again !
E350
Sacramento Delta
Excellent! Thank you for your personal reply with pictures!!! Now I know what and how to do what I want with @tom21 's bolt on tubbies for the FX-1.
Rotaloc makes a Hex Nut version and also a Threaded Sleeved version. I saw that you used the Nut version.
I like the idea of the bigger diameter bolt and how you dome epoxied the inserts in your photos. I will source a stainless steel fender-type bolt (or use SS washers).
I never knew there was a rethreader vs a tap. I will source a rethreader in the appropriate diameter.
It's your lucky day! I'm gonna save you a whole bunch of time and $. You'll need 3/8 x 2 fenders. Steel or ss steel, doesn't matter. A piece of 1 1/2 pipe, steel or ss steel, I use ss for everything, I hate rust. The pics explain it. Bevel and polish the edge of the pipe. Use the stack of washers to control how much you dish the washer. Different heights, for different Roto's. I was at the limit for height on my M10's w/2" fenders, you can only dish so far. A control bolt thru the stack, put it in the press. I've used a vise for quick and dirties but the press works better. If you want to thank me, just call it the Mikey-Cert-System, lol.
E350
Sacramento Delta
I like the Mikey-Cert-System !
But where did you get the beveled or cone washers?
Very cool, the Mikey-Cert-System with epoxy form/press.
Or better yet, how much do I send you via Zelle or PayPal to buy my own Mikey-Cert-System™ epoxy form/press?
Cone washer ?
While posting about dishing washers I've actually been making a pole pad, 1st real time post here. I was just going to glue down a 4" block, of course the curve of the hood ruined that plan. So I contoured it. And that made it to short, my pole hit the strap bolts. So I built it up and have been posting in between glue cure times.
DSC05933.JPGDSC05934.JPGDSC05935.JPGDSC05936.JPGDSC05939.JPGDSC05940.JPGDSC05941.JPGDSC05942.JPG
E350
Sacramento Delta
Got it. I have the H.F. press so I can make those dish washers. (But would gladly pay for the Mikeysx kit.)
